It is currently Thu Aug 14, 2025 6:26 am
PostPosted: Tue Jun 09, 2015 11:16 am
First name: George
City: Seattle
I had a bit of this with koa on my 10-20. Lighter, quicker passes using 60 grit and frequently changing to fresh paper was my solution.
George :-)
PostPosted: Tue Jun 09, 2015 7:02 pm
James, I've experienced this with Black Acacia as well. You have to go as lightly as you can with the passes, and sanding on an angle does indeed help a bit.
I wouldn't have expected issues with 100 grit, but if you have to go with 80, do so just remember not to go too thin so that you can't get the scratches out.
PostPosted: Tue Jun 09, 2015 9:54 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
James Orr wrote:
That's the thing! In the seven years I've had it, burning has never been an issue! [headinwall] :shock: :D
I'm using double sides for the first time, so I'm sanding the sides quite a bit thinner than I'm used to. I got my rosewood down to .055 without any problems, but I really don't want to take chances with the koa considering how scarce and expensive it's become. The backing board might be a great idea.
Yeah, at that thickness I would def use a backer board. With my setup, I recently made veneer at 0.6 mm. I'm uncomfortable below .1"
PostPosted: Tue Jun 16, 2015 12:14 am
I had a good day with the sander on Friday, replacing the conveyor and height adjustment screw before getting to work on the wood.
I got the koa down to .065" without the slightest issue. I ran the conveyor at 7, made 1/8th of a turn adjustments on the drum height, and took two passes for each. Some of the sanding scratches are deeper than others and I'm deciding whether to scrape it smooth now (I've already sanded each face of the sides with 120), or wait until I'm prepping for finish. I'm leaning towards waiting in order to take off as little as possible.
Thanks for all the help!
PostPosted: Tue Jun 16, 2015 5:30 am
Glad you got it working! I sand my parts to 220 after they are thicknessed but before assembly.
PostPosted: Tue Jun 16, 2015 11:52 am
First name: Rodger
Last Name: Knox
City: Baltimore
Zip/Postal Code: 21234
Same general ideas, but slightly different numbers. Performax 16-32 with 120 grit, 1/10 to 1/12 turn, 2 to 4 passes, depending on the sound, I can hear when it's working too hard. Dust collection with a shopvac, so not that great. Inboard is 0.003" less than outboard. I've taken bloodwood and mesquite down to 0.06" without a carrier board.
Users browsing this forum: rbuddy and 21 guests
